This command displays tech-support configuration and report status.
hostname | Specifies the host name of the collector. |
ip_address | Specifies the IPv4 address of the collector. |
NA.
This commands displays tech-support configuration and report status, such as last report stats, when the next cyclic report is sent if report frequency daily is configured, and when the next one time report is sent if one time report is scheduled with run tech-support in hours command. If you do not specify a hostname or IP address, this command displays configuration and report status for all existing collectors; otherwise it displays configuration and report status for the specified collector.
The following is an example of the show output:
Tech Support Collector: Enabled Report Collector: 10.5.2.107 TCP Port: 9998 Virtual Router: VR-Mgmt Source IP Addr: 10.66.24.234 SSL: Off Report Mode: Automatic Report Data Set: Summary Report Frequency: Error-detected AND Daily at 0:00 Last Report: Successful Sent On: Thu Feb 21 05:06:32 2013 From: 10.66.24.234:3546 To: 10.5.2.107:9998 SSL: Off Error: None Next Cyclic Report: Scheduled on Fri Feb 22 00:00:00 2013 Next One Time Report: Not Scheduled Report Collector: 10.5.2.108 TCP Port: 800 Virtual Router: VR-Mgmt Source IP Addr: 10.66.24.234 SSL: On Report Mode: Automatic Report Data Set: Detail Report Frequency: Bootup AND Daily at 0:00 Last Report: Failed Sent On: Thu Feb 21 05:06:32 2013 From: 10.66.24.234:3598 To: 10.5.2.107:800 SSL: On Error: Socket time out Next Cyclic Report: Scheduled on Fri Feb 22 00:00:00 2013 Next One Time Report: Not Scheduled
This command was first available in ExtremeXOS 15.4.
